Auf der Suche nach der Handlichkeit...
Pablo
Re: Auf der Suche nach der Handlichkeit...
Beitragvon Pablo » Mi Mär 01, 2023 16:41
Thanks !
Yes, I love this green paint of the tank. And I ve use John deere green paint for the fenders, it s really almost the same!!
Pablo
Beitragvon Pablo » Mi Mär 01, 2023 16:48
Here almost finished and in Dakar version...
Pablo
Beitragvon Pablo » Mi Mär 01, 2023 16:54
And the frame just welded...
Lulatsch
Beitragvon Lulatsch » Do Mär 02, 2023 12:19
Hi Paplo, I also like green :) nice bike!
Did you lower the swing arm pivot in the frame? It looks as if your swing arm is quite steep. I guess that works well for you anyway? Also what kind of swing arm ist that? Suzuki? Looks modified too.
Pablo
Beitragvon Pablo » Do Mär 02, 2023 14:03
Hi.
morning.
no I did not modify the anchoring of the oscillating arm. it is certainly better, but my level of piloting is very happy without it!
It is indeed a Suzuki swing arm, PE 250 from memory. shortens.....
hershey
Beitragvon hershey » Fr Mär 03, 2023 8:39
Good job, Pablo!
In my early XT-days I built a swingarm (no mods on the frame) which looked as steep as yours. I had huge problems with traction, because the rear suspension stiffened while accelleration. Maybe yours works well because you use other dampers?
Pablo
Beitragvon Pablo » Fr Mär 03, 2023 11:13
Ah yes. I haven t this problem. Maybe because I ve modified the frame and the high anchoring of damper To keep them near To a 45° inclination.... with 400mm long damper...
Maybe yours are too vertical.....
Pablo
Beitragvon Pablo » Fr Mär 03, 2023 15:11
hershey
Beitragvon hershey » Fr Mär 03, 2023 16:47
OK, rear-end looks reasonable :zustimm:
I don't have any picture of my old XT and the steep swingarm, because I changed it immediately to shorter shocks which solved the problem.
This is my current XT, which I bought 12 years ago. I ride it in this condition since 9 years.
No frame mods though:
Lulatsch
Beitragvon Lulatsch » Fr Mär 03, 2023 19:51
interesting, thanks Pablo
Pablo
Beitragvon Pablo » So Mär 05, 2023 11:40
one of the motorcycles that inspired me.... I realize that it strongly resembles the one at the beginning of the post.....! :D
and some measuring frames with the horizontal underseat tube as a reference.
Original
Barigo
Bye
Beitragvon Frank M » So Mär 05, 2023 13:18
it is the same motorcycle, in an earlier rebuild state.
Beitragvon Frank M » Do Okt 05, 2023 17:24
passend zum Tag der deutschen Einheit bin ich mit meinem großen Sohn am 03.10. in den Osten zur Area39 gefahren und konnte endlich die Rahmenänderung in angemessener Umgebung testen. Das Offroadgelände in 39397 Gröningen hat eine MX-Strecke, Singletrails, Enduropisten mit Steilauf- und Abfahrten, Freifahrtbereiche usw.. Also genau das Richtige, um ausgiebig rumzuprobieren.
Meine Bedenken wegen zuwenig Nachlauf und einer daraus resultierenden nervösen Lenkung erwiesen sich als unbegründet. Auch auf schnellen buckligen Vollgaspassagen keine Tendenz zum Lenkerschlagen oder sonst irgendwie verschlechtertem Geradeauslauf. Das Kurvenverhalten würde ich (gegenüber vorher) als excellent bezeichnen. Selbst im Kleinklein mit engen, steilen Sandauffahrten mit Kurven und Kehren lässt sich alles präzise wie angesteuert durchfahren. Schnelle Hartbodenkurven mit losem Schotter drauf gehen mit Kopf überm Lenker im Stehen, bei (zu) hartem Rausbeschleunigen aus Kurven spurt das Vorderrad und das Hinterrad leitet einen kontrollierbaren Drift ein. Die Tendenz zum Untersteuern mit schiebendem Vorderrad ist vollständig weg (konnte ich erst gar nicht glauben). Somit war die Änderung des Lenkkopfwinkels exakt die richtige Lösung für ein deutlich handlicheres Fahrwerk in einem XT500-Rahmen mit längeren Federwegen.
Üblicherweise DER ideale Untergrund für eine XT mit langem Radstand ist eine echte Tiefsandpiste. Die fehlt mir jetzt noch als Testumgebung. Am 04.11. beim Endurotraining in Mölln findet sich vielleicht was...
viewtopic.php?t=15513
hershey
Beitragvon hershey » Do Okt 05, 2023 18:46
good job! :zustimm:
Beitragvon Mambu » Fr Okt 06, 2023 7:00
...jepp, hört sich nach einem gelungenen Plan an! :top: :dance
