Piston 93.5 Wossner
Re: Piston 93.5 Wossner
Beitragvon Mambu » Do Jan 19, 2023 8:28
...here you find some pictures:
https://www.xt500.org/68eustw03ihkmsez/ ... er#p162981
But I can send you some more if you like.
I'm sure it is a different casting compared to the DreiBuchstabenMann part.
Hans are you sure about this? I've never heard about this. I believe he used his "own" casting and also sold these to others.
Beitragvon Hiha » Do Jan 19, 2023 10:06
There was a discussion about it some years ago, but I don't remember where. Ask Kuntzinger, maybe he knows more about it.
Pablo
Beitragvon Pablo » Do Jan 19, 2023 10:16
and what about the solidity of these cylinders..
Pablo
Beitragvon Pablo » Do Jan 19, 2023 10:47
Thank you for the photos,
indeed it strongly resembles the JPX, fins above the chain tensioner, reinforcement between fins ....
here is a JPX (in the middle) and two Rayer....
the fabrications between the two are completely different.
i will ask around about JPX nikasil....
Beitragvon Mambu » Do Jan 19, 2023 11:07
...nice photos, thanks!
The DreiBuchstabenMann-cylinders are very reliable, but the machining by 3BM is quite poor, the Pami configuration together with a CP or JE piston is much better.
Pablo
Beitragvon Pablo » Do Jan 19, 2023 12:08
Well nice Thanks!
Pablo
Beitragvon Pablo » Do Jan 19, 2023 13:08
Hi
do you have more pics of the cylinder?
above and below...
thank you
Beitragvon Mambu » Do Jan 19, 2023 16:58
...I posted some new pictures here:
https://www.xt500.org/68eustw03ihkmsez/ ... 60#p166560
In my opinion it must be a JPX... :wink:
Theo
Beitragvon Theo » Fr Jan 20, 2023 16:45
In 2011 I bought a Mahle piston which was finished by Helmut Wahl to 93.5mm and prepared for 88mm stroke without the need of an additional cylinder gasket (2mm).
It has a complete weight of 476g incl. clips, rings and piston pin.
Cylinder is definitely RAHIER.
The price for the custom made piston was 318€ incl. taxes.
Kind regards, Theo
PS: I have a second Rahier kit which has done more than 100.000km up to now with first piston and rings, still needs only little amount of oil :)
Erlaubt ist, was gefällt !
Pablo
Beitragvon Pablo » Fr Jan 20, 2023 18:20
thank you for your experience.
Mr Rahier Gaston was a pilot.....
Mr Rayer Christian, a kit maker....
in terms of the longevity of the kit and its sobriety in oil is strongly due to the famous U-flex scraper segment of a special technology .... and unfortunately not found nowadays ...
but the cylinder is not a Rayer, far from it.
maybe a JPX but I have doubts if it is not a reported shirt....
namely mr Rayer is still selling 2 or 3 kits which will have a 94mm Wossner piston...
and shirts...
Beitragvon Hiha » Fr Jan 20, 2023 22:23
NOTHING he does is reliable...
Cheers,
Beitragvon Mambu » Fr Jan 20, 2023 23:11
Cheers,
I'm only talking about the cylinder itself, whoever casted them ... :wink:
... not the machining... :lach:
I've never heard that one of these cylinders cracked... :roll:
Pablo
Beitragvon Pablo » Mi Feb 15, 2023 10:56
I ve compare my proto 94mm by Wossner and your plan and a 89mm Wossner piston (8505)....
Your plan look exactly like the 8505. Expect the diameter of course....
And looking the two piston I easy find who one is lighter than the other....
So I ll made a mix....
A 8505 with a less curved dome (compression 9:1) and diameter 93.5....
Thanks for your expérience !
Zurück zu „Tuning“
