Technical problem
This board should be in english only and contains everything worth to discuss.
aievouais64
Technical problem
Beitragvon aievouais64 » So Mär 29, 2009 13:52
Hello every body.
When you look at the part list onthis page, you can see the washer number 15. It is alone.$
we disassembled 2 motors and we found on the first a stacking up of 10 chocks (2.36 mm) behind this washer.
On the second motor we found just one (2.50 mm).
On my motors, there is just the number 15 washer.
Who would have an explanation on the presence of this additional wedging while list leaves him do not speak about it? Already have you to meet this problem?
Thanks
speedphreax
Re: Technical problem
Beitragvon speedphreax » So Mär 29, 2009 15:43
It depends on the year the bike was manufactured. Pre 1981 XT's have a two row bearing behind the clutch and a 1981-on XT has a single row bearing. The 1981-on needs the extra spacer, the pre-1981 doesn't.
The picture that shows the 10 shims is just a nasty solution that is probably done by one of the previous owners.
By the way... There is allready a topic about this issue on this forum: http://www.xt500.org/68eustw03ihkmsez/v ... f=2&t=6251
Kneedown is for pussies...
Jeanjean
Beitragvon Jeanjean » So Mär 29, 2009 19:53
Hat jemand die Yamaha-Referenznummer der 3 mm-Ausgleichsscheibe, die mit dem einreihigen 6205-Lager verbaut wurde ?
Does someone know what's the part number of the 3 mm spacer for the 6205 single row bearing ?
Quelqu'un connait-il la référence yam de la rondelle de calage montée avec le roulement simple rangée de bille 6205 ?
No parla italiano...
jeanjean
Zurück zu „International“
